[GRASS-user] grass72 or higher on RHEL6
Markus Neteler
neteler at osgeo.org
Thu Feb 2 06:40:10 PST 2017
Hi Anna,
On Wed, Feb 1, 2017 at 3:23 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Wed, Feb 1, 2017 at 5:21 AM, joerg robl <joerg.robl at gmail.com> wrote:
>> I’ve compiled grass from source up to version 7.1 but unfortunately I get
>> compilation errors compiling grass72 or higher (the configure script does
>> not complain about any problems). It seems the compilation problems may be
>> related to the rather old matplotlib (0.9x) while grass requires matplotlib
>>> 1.2. As a result, the GRASS GUI crashes after the startup. Of course it
>> may be possible to compile matplotlib from source, which however requires a
>> higher version of numpy which in turn requires at least python2.7x instead
>> of the installed python 2.6x. Not necessary to say that after compiling and
>> installing python2.7x the wxPhyton libs would also require an update … ! At
>> that point I ended up compiling grass72 on RHEL6.
> could you show us any errors you are getting during compilation or
> startup? Matplotlib is not a core component, so this should be
> solvable.
I am currently trying to compile 7.2 on EPEL6 using Fedora's COPR platform.
At time I struggle here:
DEBUG util.py:435: Error: No Package found for python-matplotlib-wx
see
https://copr-be.cloud.fedoraproject.org/results/neteler/grass72_epel6/epel-6-x86_64/00502967-grass/root.log.gz
with which configure flag can I disable this part since
python-matplotlib-wx will not be there (I tried for a while to compile
that but no way it seems)?
thanks
Markus
