[GRASS-user] CHELSA climate data set
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Feb 10 08:53:07 PST 2017
On 10-02-17 17:15, Markus Metz wrote:
> On Tue, Feb 7, 2017 at 3:43 PM, Markus Neteler <neteler at osgeo.org
> <mailto:neteler at osgeo.org>> wrote:
> > On Tue, Feb 7, 2017 at 3:32 PM, Markus Metz
> > <markus.metz.giswork at gmail.com
> <mailto:markus.metz.giswork at gmail.com>> wrote:
> > > Unfortunately it changes East from 179.9998611 to 179.9998597 and
> north
> > > from 83.9998611 to 83.9998604.
> > > The more serious problem is that GRASS can not handle ll
> coordinates like
> > > 180:0:0.50W or 90:0:0.5S.
> > > I have relaxed the ll restrictions in my local copy and can now import
> > > CHELSA and other for GRASS problematic ll datasets without getting
> e.g. a
> > > narrow N-S strip, or GRASS fixing a subtle rounding error that in
> fact is
> > > not an error. That means after each import I have to manually check if
> > > resolution and extents make sense, and if in doubt fix them with
> r.region.
> > That's probably rather more a power user task than common user
> > knowledge...
> Why a power user task? r.region is an easy to use module, as long as
> you know the correct grid geometry. And with my relaxed ll
> restrictions I get less errors and more usable results, in fact I need
> to use r.region less often than before.
Not sure that is what Markus meant, but "relaxed the restriction in my
local copy" sounds definitely like a power user task to me. If this is
something that can, and will, be done at the libgis level, great.
Otherwise, I would be interested to know how to do this.
> > Is there anything we could do at libgis level like
> > relaxing the ll restrictions along with appropriate user messages?
> Yes. The first points would be ll_scan.c, ll_format.c and
> adj_cellhd.c. That should also remove cryptic errors like "ERROR:
> Syntax error in cell header".
> > More and more global datasets are getting published, so the issue will
> > likely come up more frequently. Just to make it a bit easier :-)
> For a start, it would be nice if you can create a full SRTM mosaik
> (not so new data) in GRASS.
> Markus M
> > markusN
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170210/ea9b297d/attachment.html>
