[GRASS-user] error with imported kml file
    Anna Petrášová
    kratochanna at gmail.com
    Sun Feb 12 17:13:35 PST 2017
On Sun, Feb 12, 2017 at 5:42 PM, Stuart Edwards <sedwards2 at cinci.rr.com> wrote:
> Anna
> Thanks for the quick response.
> Here's the output from v.what -j for the query in the screenshot:
> (Sun Feb 12 17:14:20 2017)
> v.what -j map=DBT___Waste___3D at corH coordinates=-79:45:47.0628,
> 39:05:14.8848
> {"Coordinates": {"East": "79W", "North": "39N"},
> "Maps":
> [{"Map": "DBT___Waste___3D",
> "Mapset": "corH"}
> (Sun Feb 12 17:14:21 2017) Command finished (0 sec)
> Output from v.db.select (same query):
> (Sun Feb 12 17:19:57 2017)
> v.db.select --overwrite map=DBT___Waste___3D at corH
> file=/Users/sesMacBook/Baker/CorridorH/WasteDisposal/vdbselect1
> (Sun Feb 12 17:19:57 2017) Command finished (0 sec)
Looking at the attachment, the problem is definitely in multiline
strings in your 'description' column. I suggest to create a ticket for
this. For now, you might want to consider deleting that column if it
is not needed, to be able to use the vector.
Anna
> Another kml contour file (from a different source) displayed in the same
> mapset produces better results from a query:
> east, north: -79.7618228288, 39.0853199854
> DESIGN_MAJOR_CONTOURS at corH:
>   Type: Line
>   Length: 106.682658
>   Line_height: 691.997
>   Layer: 1
>   Category: 1
>   Driver: sqlite
>   Database: /Users/sesMacBook/grassdata/KML/corH/sqlite/sqlite.db
>   Table: DESIGN_MAJOR_CONTOURS
>   Key_column: cat
>   Attributes:
>     cat: 1
>     altitudeMode: absolute
>     tessellate: -1
>     extrude: -1
>     visibility: -1
> However, the v.what -j command produces a similar result to the one above:
> (Sun Feb 12 17:29:12 2017)
> v.what -j map=DESIGN_MAJOR_CONTOURS at corH coordinates=-79.7618228288,
> 39.0853199854
> {"Coordinates": {"East": "79:45:42.562184W", "North": "39:05:07.151947N"},
> "Maps":
> [{"Map": "DESIGN_MAJOR_CONTOURS",
> "Mapset": "corH"}
> (Sun Feb 12 17:29:12 2017) Command finished (0 sec)
> and the v.db.select output is much shorter:
> (Sun Feb 12 17:35:44 2017)
> v.db.select --overwrite map=DESIGN_MAJOR_CONTOURS at corH
> file=/Users/sesMacBook/Baker/CorridorH/WasteDisposal/vdbselect2
> (Sun Feb 12 17:35:44 2017) Command finished (0 sec)
> produces:
> cat|Name|description|timestamp|begin|end|altitudeMode|tessellate|extrude|visibility|drawOrder|icon
> 1|Style2|||||absolute|-1|-1|-1||
> I can send you the two kml files if that would be helpful.
> thx
> Stu
> On Feb 12, 2017, at 3:44 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> Hi,
> On Sun, Feb 12, 2017 at 10:36 AM, Stuart Edwards <sedwards2 at cinci.rr.com>
> wrote:
>> Hi -
>> I have imported a kml file that contains contours of a feature of
>> interest. Functionally an x,y,z data set.  It displays correctly in GRASS.
>> When queried to determine the value of z, the attached error is given that
>> indicates a lack of conformance with JSON formatting.  The values of z are
>> given for the feature in the error message but additional processing such as
>> v.to.rast does not work.  GRASS is able to label the contours correctly.
>> Using the attribute table manager is not much help - it produces an error
>> that indicates 'Inconsistent number of columns in table'.
>> I see that there is a bug report (3133) that reflects the same problem but
>> has been fixed in 7.0.5 - I'm getting the 'same' error in 7.3.svn. (on OS X
>> 10.10.5)
>> The error message is too long to fit on the monitor - and is not
>> scrollable, so the full content is not visible.
>> Any assistance or advice much appreciated.
> please post (or attach) the text outputs of v.what with -j flag and
> v.db.select, which are the backend commands behind the GUI dialogs. That
> helps us to analyze it.
> Anna
>> Stu
>> <Screen Shot 2017-02-12 at 10.29.33 AM.png>
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
