[GRASS-user] Help with v.select with GRASS GIS 7.2
Markus Neteler
neteler at osgeo.org
Wed Feb 22 12:26:18 PST 2017
On Mon, Feb 20, 2017 at 10:41 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> Hi all!
> I'm trying to use v.select to find the intersection/crossings of a pipeline
> path across a stream network...
> v.select -r --overwrite ainput=pipeline_streams at teaiii atype=line
> binput=mvp_path at teaiii btype=line output=mvp_stream_crossings
> operator=crosses
> I've tried several options of crosses, intersects, overlap, etc., with and
> without 'reverse', each time getting:
> Output:
> Processing features...
> ERROR: IllegalArgumentException: point array must contain 0 or >1 elements
Could you create an example with the NC sample dataset?
Markus
