[GRASS-user] Zonal Raster Statistics with overlapping polygons
    Moritz Lennert
    mlennert at club.worldonline.be
    Mon Feb 27 03:47:31 PST 2017
Le Mon, 27 Feb 2017 12:35:11 +0100,
Moritz Lennert <mlennert at club.worldonline.be> a écrit :
> Le Mon, 27 Feb 2017 09:41:11 +0100,
> Leonardo <leonardo at mobygis.com> a écrit :
> Well the "smarter" in your case would imply to use non-topological
> vector format, which was decided for GRASS GIS to not be "smarter".
> Yes, this makes some operations a bit more complicated, but you get
> paid back with so much less hassle because of spaghetti data. And
> writing a simple loop over v.rast.stats is not that difficult. The
> only difficulty I see is that v.rast.stats does not have a where= nor
> cat= feature selection parameter. This implies that you have to run
> v.extract each time. Having these parameters would certainly be useful
> and you could file an enhancement wish for those/
> I don't know why this would be less "clean"...
> The IMHO "cleanest" solution is actually the one that GRASS GIS
> implements: When you import a file with overlapping polygons, GRASS
> GIS creates a vector map in which the overlapping parts of the
> polygons have the category ids of all the polygons that overlap in
> that area. And when you run v.rast.stats on that, it will fill the
> total of each category value in the attribute table.
> Attached you can find an image of a test map with polygon 3
> overlapping both polygon 1 and 2. I also created a second file with
> only the 2 non-overlapping polygons. Those two were created in QGIS
> so as to be able to have "nice" topologically incorrect data.
> I then imported the two files into GRASS GIS with v.in.ogr and ran
> v.rast.stats map=test raster=elevation column_prefix=e
> v.rast.stats map=test_nooverlap raster=elevation column_prefix=e
> And here are the results:
> > v.db.select test
> cat|id|e_number|e_minimum|e_maximum|e_range|e_average|e_stddev|e_variance|e_coeff_var|e_sum|e_first_quartile|e_median|e_third_quartile|e_percentile_90
> 1|1|242621|76.8941955566406|145.712738037109|68.8185424804688|114.397437714797|13.5650727983398|184.01120002426|11.8578467047128|27755220.7358017|104.996|115.337|124.654|131.38
> 2|2|131854|77.3364105224609|126.733070373535|49.3966598510742|99.4588066985328|10.6819214497898|114.103445859479|10.7400458585508|13114041.4984283|91.5773|98.7388|106.926|114.645
> 3|3|99039|71.4758224487305|139.941131591797|68.4653091430664|107.223648245541|13.7481896908839|189.012719776527|12.8219752972784|10619322.8985901|97.4993|105.891|118.752|126.703
> > v.db.select test_nooverlap
> You can see that the values for polygons 1 and 2 are strictly
> identical. Overlapping areas are thus correctly taken into account.
> To test even further, I ran
> v.extract -d test cat=3 out=test3
> to get the entire polygon with cat=3.
> Then
> v.rast.stats test3 rast=elevation colprefix=e -c
> > v.db.select test3
> 3|3|224074|71.4758224487305|141.793502807617|70.3176803588867|110.21428988784|13.2281044492473|174.982747320197|12.0021681968|24696156.7923279|100.265|110.004|120.916|127.836
> There thus seems to be a bug in v.rast.stats as it does not calculate
> the correct values for the polygon with cat=3 when there area polygons
> with multiple cat values.
> I'll post a bug report.
Done: https://trac.osgeo.org/grass/ticket/3300
Moritz
