[GRASS-user] help v.lidar.mcc
Anna Petrášová
kratochanna at gmail.com
Mon Jan 9 11:46:53 PST 2017
There should be some error in terminal too, could you include it?
On Mon, Jan 9, 2017 at 2:43 PM, Rafaela Soares <rafaelaniemann at gmail.com> wrote:
> Hi Moritz!
> I've reinstalled v.lidar.mcc using g.extension in another computer, but it
> seems that it did not work.
> He returned this report:
> (Mon Jan 9 13:39:58 2017)
> v.lidar.mcc input=q16_p02 at q16_total_jun2016 ground=q16_p02gro
> nonground=q16_p02nongro
> Processing scale domain 1...
> Processing scale domain 2...
> Traceback (most recent call last):
> File "/home/carlos/.grass7/addons/scripts/v.lidar.mcc",
> line 278, in <module>
> sys.exit(main())
> line 229, in main
> overwrite=True, quiet=True, stderr=nuldev)
> File "/usr/lib/grass73/etc/python/grass/script/core.py",
> line 410, in run_command
> return handle_errors(returncode, returncode, args,
> kwargs)
> line 329, in handle_errors
> returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None
> ['v.outlier', '--o', '--q', 'ew_step=0.5',
> 'outlier=v_lidar_mcc_tmp_ng_8330', 'filter=positive',
> 'lambda=2.0', 'input=v_lidar_mcc_tmp_ncin_8330',
> 'threshold=0.4', 'output=v_lidar_mcc_tmp_ncout_8330',
> 'ns_step=0.5'] ended with error
> Process ended with non-zero return code 1. See errors in the
> (error) output.
> (Mon Jan 9 17:06:51 2017) Comando terminado (206 min 53 sec)
> Best Regards,
> *Rafaela Soares Niemann*
> Geografa - Universidade Estadual de Campinas - UNICAMP
> Mestranda em Geografia - Universidade Estadual Paulista - UNESP Rio Claro
> 2017-01-09 13:32 GMT-02:00 Moritz Lennert <mlennert at club.worldonline.be>:
>> On 09/01/17 16:11, Rafaela Soares wrote:
>>> Hi Anna,
>>> Thanks for your attention.
>>> The module v.lidar.mcc creates two products (point cloud): ground and
>>> non-ground. So, after I installed Linux Mint on my computer, the module
>>> is not creating ground file, only file of non-ground and also files I'm
>>> not understanding what it are.
>>> Example for output:
>>> /home/eddard/Downloads/v.lidar.mcc.py <http://v.lidar.mcc.py>
>>> input=q16 at q16_total g_output=q16_gro ng_output=q16_ngro
>>> File "/home/eddard/Downloads/v.lidar.mcc.py <http://v.lidar.mcc.py>",
>>> line 243, in
>>> <module>
>>> sys.exit(main())
>>> line 214, in
>>> main
>>> grass.run_command('g.remove', vect = temp_ncin, quiet =
>>> True, stderr = nuldev)
>>> kwargs)
>>> ['g.remove', '--q', 'vect=v_lidar_mcc_tmp_ncin_18102'] ended
>>> with error
>>> (error) output.
>>> Error in atexit._run_exitfuncs:
>>> File "/usr/lib/python2.7/atexit.py", line 24, in
>>> _run_exitfuncs
>>> func(*targs, **kargs)
>>> line 106, in
>>> cleanup
>>> grass.run_command('g.remove', vect = '%s,%s,%s' %
>>> (temp_ng, temp_ncin, temp_ncout), quiet = True, stderr =
>>> nuldev)
>>> kwargs)
>>> CalledModuleError: Module run None ['g.remove', '--q', 'vect
>>> =v_lidar_mcc_tmp_ng_18102,v_lidar_mcc_tmp_ncin_18102,v_lidar
>>> _mcc_tmp_ncout_18102'] ended with error
>>> (error) output.
>>> Error in sys.exitfunc:
>>> _run_exitfuncs
>>> line 106, in
>>> cleanup
>>> nuldev)
>>> kwargs)
>>> ['g.remove', '--q', 'vect=v_lidar_mcc_tmp_ng_18102,v_lidar_m
>>> cc_tmp_ncin_18102,v_lidar_mcc_tmp_ncout_18102'] ended with
>>> error
>>> (error) output.
>>> (Mon Dec 5 22:28:30 2016) Comando terminado (4983 min 19 sec)
>>> What can I do wrong?
>> I don't think you are doing anything wrong. It rather looks like the
>> version you use is and old version of v.lidar.mcc. The parameters of
>> g.remove have changed in grass 7 and v.lidar.mcc does not use a call such as
>> "grass.run_command('g.remove', vect = '%s,%s,%s'" anymore.
>> Try reinstalling v.lidar.mcc using g.extension.
>> Moritz
