[GRASS-user] update column w/ output from bash function
    Helmut Kudrnovsky
    hellik at web.de
    Fri Jan 13 00:42:50 PST 2017
Ken Mankoff wrote
> Hi Stefan,
> Your code didn't seem to work for me, but allowed me to figure out how to
> make it work. This does:
> db.execute sql="UPDATE CTD_2015 SET YMD=date('2015-01-01', +CAST(DOY AS
> text) || ' days');"
> I'm not sure why I can't simplify this to:
> db.execute sql="UPDATE CTD_2015 SET YMD=date('2015-01-01', '+DOY days');"
> But it is OK.
> Thank you for the hint,
>   -k.
> On 2017-01-12 at 21:17, Blumentrath, Stefan <
> Stefan.Blumentrath@
> > wrote:
>> Hi Ken,
>> In SQLite it would look like this:
>> SELECT substr(CAST(date('2015-01-01', +CAST(DOY -1 AS text) || '
>> days') AS text), 6, 2);
>> Or
>> SELECT CAST(ltrim(substr(CAST(date(CAST(2015 AS text) || '-01-01',
>> +CAST(2-1 AS text) || ' days') AS text), 6, 2), '0')as smallint)
>> If you want numeric return.
>> Thus, try:
>> db.select sql="SELECT substr(CAST(date('2015-01-01', +CAST(134 -1 AS
>> text) || ' days') AS text), 6, 2);"
>> To see how it works...
>> Then try something like:
>> v.db.update map=CTD_2015 column=YMD value=
>> substr(CAST(date('2015-01-01', +CAST(DOY -1 AS text) || ' days') AS
>> text), 6, 2)
>> or
>> db.select sql="UPDATE CTD_2015 SET YMD =
>> substr(CAST(date('2015-01-01', +CAST(134 -1 AS text) || ' days') AS
>> text), 6, 2);"
>> Cheers
>> Stefan
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
Would you mind to add some notes regarding date conversion to the wiki?
https://grasswiki.osgeo.org/wiki/GRASS-Wiki
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/update-column-w-output-from-bash-function-tp5303075p5303302.html
Sent from the Grass - Users mailing list archive at Nabble.com.
