[GRASS-user] Image segmentation
Markus Metz
markus.metz.giswork at gmail.com
Wed Jan 18 23:38:42 PST 2017
On Wed, Jan 18, 2017 at 8:16 PM, Giuseppe Amatulli <
giuseppe.amatulli at gmail.com> wrote:
> Hi all,
> I would like to "segment" an image using a sort of Voronoi algorithm on a
cost surface instead of distance between point.
> Below you can see an image where the black pixels identity areas with
high cost value. I would like to identify the "valley" between theses black
areas.
> In the second image I draft by hand an ideal solution for few high cost
areas.
> Which grass command can do this kind of delineation?
You can use v.voronoi: first extract the pixels with high cost values with
e.g.
r.mapcalc "high_cost = if(surface_map > threshold_value, 1, null())"
Then convert to vector areas with
r.to.vect input=high_cost output=high_cost type=area
Now create Voronoi triangles for areas with
v.voronoi input=high_cost output=high_cost_voronoi -a
HTH,
Markus M
> Thanks,
> Giuseppe
> Giuseppe Amatulli, Ph.D.
> Research scientist at
> Yale School of Forestry & Environmental Studies
> Yale Center for Research Computing
> Center for Science and Social Science Information
> New Haven, 06511
> Teaching: http://spatial-ecology.org
> Work: https://environment.yale.edu/profile/giuseppe-amatulli/
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170119/475f627e/attachment.html>
