[GRASS-user] GRASS 7.2 v.in.ascii error
Thomas Adams
tea3rd at gmail.com
Fri Jan 20 04:15:16 PST 2017
Helmut,
Thank you; I did try 'date' and got the same result using the exact
dataset. After sending out the email (thinking GRASS *might* be choking on
the number of columns), I reduced the number of columns and re-ordered them
(thinking that maybe the ID ought to come first -- also recognizing that
this should NOT be the case). I got the same error -- then, I did as you
have suggested, using 'datetime' instead of 'time' -- this worked. So, it
almost certainly was the use of 'time' or 'date' as a column name...
At some point I'll go back to the original dataset to verify this.
Thank you...
Best,
Tom
On Thu, Jan 19, 2017 at 3:27 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> >SQL parser error (syntax error, unexpected TIME, expecting
> >NAME processing 'time') in statement:
> Could it be that time is a SQL reserved word/key? Try another word instead
> of 'time'.
> HTH
> Helmut
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/GRASS-7-2-v-in-ascii-error-tp5304079p5304089.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170120/2569665d/attachment.html>
