[GRASS-user] Question to the input seed grid of i.segment
Moritz Lennert
mlennert at club.worldonline.be
Thu Jan 26 04:16:54 PST 2017
On 25/01/17 11:22, Moritz Lennert wrote:
> On 24/01/17 20:40, Raphael Knevels wrote:
>> " You could try using the brand new i.superpixels.slic add-on to create superpixels which you can then use as seeds."
>> -> I could successfully install and open it ("g.extension i.superpixels.slic", GRASS 7.2.0).
>> However, when I run the tool with default settings, GRASS gives a problem message and finishs the process.
> Ok, this sounds like bug #3247 [1] for which the author hasn't applied
> the fix, yet. Rashad, will you have the opportunity to apply just the
> fix for the actual bug (not necessarily the other proposals in the
> patch), soon, or should I do it ?
FYI: I've taken the liberty to commit the proposed fix for this bug. It
is available for self-compilation, but the windows binaries installed
with g.extension will only be available tomorrow morning.
Moritz
