[GRASS-user] Error 126 with Windows 10
John Wall
jwall at ncsu.edu
Thu Jul 13 09:28:12 PDT 2017
Hello all,
I talked with Vashek offline and he metnioned I should try to uninstall and
reinstall. I did that. We then tried d.rast which threw this error:
d.rast
File "C:\OSGEO4~1\apps\grass\grass-7.2.1/gui/wxpython/gui_core/forms.py",
line 2962, in <module>
app = GrassGUIApp(task)
line 2915, in __init__
wx.App.__init__(self, False)
File
"C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
line 7981, in __init__
self._BootstrapApp()
File
line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
line 2929, in OnInit
task_description=self.grass_task)
line 529, in __init__
frame=self)
line 2212, in __init__
margin=False)
File
"C:\OSGEO4~1\apps\grass\grass-7.2.1\gui\wxpython\gui_core\goutput.py", line
112, in __init__
self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
File "C:\OSGEO4~1\apps\grass\grass-7.2.1\gui\wxpython\gui_core\prompt.py",
line 143, in __init__
GPrompt.__init__(self, parent=parent, menuModel=menuModel)
line 57, in __init__
self.mapList = self._getListOfMaps()
line 101, in _getListOfMaps
result['raster'] = grass.list_strings('raster')
File "C:\OSGEO4~1\apps\grass\grass-7.2.1\etc\python\grass\script\core.py",
line 1161, in list_strings
mapset=mapset).splitlines():
line 461, in read_command
return handle_errors(returncode, stdout, args, kwargs)
line 329, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.list', '--q', '-m',
'type=raster'] ended with error
Process ended with non-zero return code -1073741515. See errors in the
(error) output.
12:10:00 PM: Debug: ..\..\include\wx/msw/private.h(697): 'UnregisterClass'
failed with error 0x00000584 (class still has open windows.).
he then recommended g.region -p which told me "gdal201.dll". He then
recommended I post this to the mailing list. Any one have any ideas?
Thanks,
John
*John Wall, **Graduate Teaching Assist.*
Earth Science Ph.D. Student
Department of Marine, Earth & Atmospheric Sciences
NC State University; *Office*: 4139 Jordan Hall
Department Profile: meas.sciences.ncsu.edu/people/jwall/
On Wed, Jul 12, 2017 at 2:09 PM, John Wall <jwall at ncsu.edu> wrote:
> Hello,
> I am attempting to get GRASS 7.2.1-1 installed on my Windows 10 machine
> using the Osgeo4w Set-up x86 utility. I chose Advanced Install and then
> Install from Internet. After installing and restarting my machine, I tried
> to start GRASS, but got the following error:
> C:\>Traceback (most recent call last):
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\gui\wxpython\wxgui.py", line
> 158, in <module>
> sys.exit(main())
> 145, in main
> app = GMApp(workspaceFile)
> 48, in __init__
> File "C:\OSGeo4W\apps\Python27\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
> 90, in OnInit
> from lmgr.frame import GMFrame
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\gui\wxpython\lmgr\frame.py",
> line 50, in <module>
> from lmgr.layertree import LayerTree, LMIcons
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\gui\wxpython\lmgr\layertree.py",
> line 38, in <module>
> from mapdisp.frame import MapFrame
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\gui\wxpython\mapdisp\frame.py",
> line 34, in <module>
> from mapdisp.toolbars import MapToolbar, NvizIcons
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\gui\wxpython\mapdisp\toolbars.py",
> line 22, in <module>
> from nviz.main import haveNviz
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\gui\wxpython\nviz\main.py",
> line 24, in <module>
> from nviz import mapwindow
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\gui\wxpython\nviz\mapwindow.py",
> line 42, in <module>
> from nviz.workspace import NvizSettings
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\gui\wxpython\nviz\workspace.py",
> line 23, in <module>
> from nviz import wxnviz
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\gui\wxpython\nviz\wxnviz.py",
> line 46, in <module>
> from grass.lib.vector import *
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\etc\python\grass\lib\vector.py",
> _libs["grass_vector.7.2.1"] = load_library("grass_vector.7.2.1")
> File "C:\OSGeo4W\apps\grass\grass-7.2.1\etc\python\grass\lib\ctypes_loader.py",
> line 62, in load_library
> return self.load(path)
> line 240, in load
> return _WindowsLibrary(path)
> line 223, in __init__
> self.cdll = ctypes.cdll.LoadLibrary(path)
> File "C:\OSGeo4W\apps\Python27\lib\ctypes\__init__.py", line 443, in
> LoadLibrary
> return self._dlltype(name)
> File "C:\OSGeo4W\apps\Python27\lib\ctypes\__init__.py", line 365, in
> __init__
> self._handle = _dlopen(self._name, mode)
> WindowsError: [Error 126] The specified module could not be found
> What do I need to do to get GRASS to launch?
> Thanks,
> John
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170713/6e0ac6d7/attachment.html>
