[GRASS-user] Error with i.colors.enhance on Windows Grass 7.21
Helmut Kudrnovsky hellik at web.de
Sat Jul 15 11:11:36 PDT 2017
andrew haywood wrote
> Hi All,
> I am getting an error using i.colors.enhance on Windoes Grass 7.2.1 which
> crashes the session.
> I get the following error in the command window.
> Any advice would be greatly appreciated.
> Cheers
> Andrew
> ((Sat Jul 15 14:25:12 2017)
> i.colors.enhance red=s1_vv_10 at PERMANENT green=s1_vh_10 at PERMANENT
> blue=s1_10_diff at PERMANENT
> Processing...
> Process Process-3:
> Traceback (most recent call last):
>   File "C:\Program Files (x86)\GRASS GIS
> 7.2.1\Python27\lib\multiprocessing\process.py", line 258, in
> _bootstrap
>     self.run()
> 7.2.1\Python27\lib\multiprocessing\process.py", line 114, in
> run
>     self._target(*self._args, **self._kwargs)
> 7.2.1\scripts\i.colors.enhance.py", line 105, in
> get_percentile_mp
>     result = get_percentile(map, percentiles)
> 7.2.1\scripts\i.colors.enhance.py", line 89, in
> get_percentile
>     percentiles=values, quiet=True)
> 7.2.1\etc\python\grass\script\core.py", line 461, in
> read_command
>     return handle_errors(returncode, stdout, args, kwargs)
> 7.2.1\etc\python\grass\script\core.py", line 329, in
> handle_errors
>     returncode=returncode)
> CalledModuleError: Module run None ['r.quantile', '--q',
> 'input=s1_10_diff at PERMANENT', 'percentiles=2,98'] ended with
> error
> Process ended with non-zero return code 255. See errors in
> the (error) output.
> Process Process-1:
> _bootstrap
>     self.run()
> run
> get_percentile_mp
> get_percentile
> read_command
> handle_errors
> 'input=s1_vv_10 at PERMANENT', 'percentiles=2,98'] ended with
> error
> the (error) output.
> Process Process-2:
> _bootstrap
>     self.run()
> run
> get_percentile_mp
> get_percentile
> read_command
> handle_errors
> 'input=s1_vh_10 at PERMANENT', 'percentiles=2,98'] ended with
> error
> the (error) output.
tested here with
System Info
GRASS version: 7.2.1
GRASS SVN revision: r71013
Build date: 2017-05-03
Build platform: x86_64-w64-mingw32
GDAL: 2.1.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
GRASS version: 7.3.svn
GRASS SVN revision: r71251
Build date: 2017-07-10
GDAL: 2.2.1
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
and the example from the manual:
https://grass.osgeo.org/grass73/manuals/i.colors.enhance.html
g.region raster=lsat7_2002_10 -p
i.colors.enhance blue=lsat7_2002_10 green=lsat7_2002_20 red=lsat7_2002_30
strength=95
it works as expected.
did you set your region to your images? could you test the manual example
with the NC sample data set?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-with-i-colors-enhance-on-Windows-Grass-7-21-tp5327995p5328003.html
Sent from the Grass - Users mailing list archive at Nabble.com.
