[GRASS-user] nn library
jon jeir at hi.is
Wed Jul 19 03:13:25 PDT 2017
I am running  GRASS GIS 7.3.svn (r68671M) on MacOSX 10.10.5
I have used g.extension to install r.surf.nnbathy and v.surf.nnbathy,
and the following command indicates that it is in the right place
(accessible from GRASS command line):
r.surf.nnbathy --help
Description:
  Interpolates a raster map using the nnbathy natural neighbor
interpolation program.
Keywords:
  vector, surface, interpolation, natural, neighbor
Usage:
  r.surf.nnbathy input=name output=name [algorithm=string] [--overwrite]
    [--help] [--verbose] [--quiet] [--ui]
Flags:
  --o   Allow output files to overwrite existing files
  --h   Print usage summary
  --v   Verbose module output
  --q   Quiet module output
  --qq  Super quiet module output
  --ui  Force launching GUI dialog
Parameters:
       input   Name of input raster map
      output   Name of output raster map
   algorithm   Settings
               options: l,nn,ns
               default: nn
                l: Linear
                nn: Sibson natural neighbor
                ns: Non-Sibsonian natural neighbor
However, issuing e.g.  [r.surf.nnbathy input=dem_ct output=dem_nn]
GRASS 7.3.svn (skeifa_river_02):~ > r.surf.nnbathy input=dem
output=dem_nn
"nnbathy" is performing the interpolation now. This may take some
time...
   File "/Users/jon/Library/GRASS/7.3/Modules/scripts/r.surf.nnbathy",
line 80, in <module>
     main()
line 75, in main
     obj.compute()
   File
"/Users/jon/Library/GRASS/7.3/Modules/etc/v.surf.nnbathy/nnbathy.py",
line 57, in compute
     stdout=fsock)
   File
"/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/grass/script/core.py",
line 84, in call
     return Popen(*args, **kwargs).wait()
   File
line 74, in __init__
     subprocess.Popen.__init__(self, args, **kwargs)
   File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py",
line 710, in __init__
     errread, errwrite)
   File
line 1335, in _execute_child
     raise child_exception
OSError: [Errno 2] No such file or directory
I suspect I need to install the nn-c library.
Does anyone have step-by-step cookbook type instructions or any
guidelines on how to do this on MacOSX?
Cheers,
Jon Eiriksson
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170719/c5e38aaa/attachment.html>
