[GRASS-user] increase performance of r.neighbors
Moritz Lennert
mlennert at club.worldonline.be
Thu Jun 1 01:59:38 PDT 2017
On 01/06/17 10:49, Giuseppe Amatulli wrote:
> Thanks all for the inputs.
> In the end I implemented a scripting procedure outside grass using
> pktools (pkfilter).
> I first tiled the image with some overlap area, than run pkfilter -f
> stdev , than crop the overlap area and then merge back the full image.
It would be interesting to find out whether this is significantly faster
than doing exactly the same within GRASS, and if yes, why. Have you tried ?
Moritz
