[GRASS-user] Change value of cells in raster map
Rich Shepard
rshepard at appl-ecosys.com
Thu Jun 8 16:57:31 PDT 2017
On Thu, 8 Jun 2017, Mark Seibel wrote:
> Maybe if-then statements with mapcalc are applicable to the situation.
> outputRaster=if(EXPRESSION,true,false)
Mark,
I'll try writing an expression that tests for a map name. I can use any
output map name because if it contains the appropriate cell values a simple
g.rename will work.
Perhaps this will work:
r.mapcalc 'output1 = if (mapname at mapset,value=0.0)'
I'll try it tomorrow morning and post the results.
Thanks,
Rich
