[GRASS-user] i.superpixels.slic not working
Moritz Lennert
mlennert at club.worldonline.be
Mon Jun 12 04:09:53 PDT 2017
On 12/06/17 12:11, James Duffy wrote:
> On 12 June 2017 at 11:00, Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>> wrote:
> On 12/06/17 11:38, James Duffy wrote:
> On 12 June 2017 at 10:36, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>
> <mailto:mlennert at club.worldonline.be>>> wrote:
> On 12/06/17 11:25, James Duffy wrote:
> Hello,
> I'm trying to run the following:
> *i.superpixels.slic -n group=mod1 at PERMANENT output=test
> num_pixels=5000
> memory=10000
> The output gives me the following:
> (Mon Jun 12 10:17:40
> 2017)
> num_pixels=5000
> memory=10000
> Cache data in memory mode
> Loading input...
> WARNING: Initialized 5036 of 5070 seeds
> Performing k mean segmentation...
> And then I get a 'GRASS 7 has stopped working' box pop up.
> I tried again with the default settings for the module:
> *i.superpixels.slic group=mod1 at PERMANENT output=test
> And got the same error.
> I am using windows 10 professional and GRASS 7.3.svn (2017).
> Has anyone else got this module working, or had the same
> problem
> on Windows?
> I haven't had any problems running it on Linux, and some
> colleagues
> have run it on Windows.
> Just for our info: What are your region settings ?
> projection: 1 (UTM)
> zone: 43
> datum: wgs84
> ellipsoid: wgs84
> north: 25183.22184529
> south: 25157.71783908
> west: 301463.66480893
> east: 301494.2431551
> nsres: 0.07775612
> ewres: 0.0778075
> rows: 328
> cols: 393
> cells: 128904
> Just to add, I am running i.segment.uspo without problems using
> the same
> imagery group and the same region.
> Yes, the region is actually very small, so no problem from there. It
> might be an issue with the memory handling. Could you try without
> setting the memory parameter, i.e. using its default value of 300
> and tell us what happens ?
> *#default memory*
> Produced the same problem.
Can you reproduce using the NC demo data set ?
I.e.
g.region rast=ortho_2001_t792_1m
i.group ortho input=ortho_2001_t792_1m
i.superpixels.slic group=ortho out=slic_test
And tying with and without the '-n' flag and the memory parameter.
Moritz
