[GRASS-user] I do not manage to launch r.massmov
Helmut Kudrnovsky hellik at web.de
Fri Jun 16 03:22:17 PDT 2017
Louis DEMANGE wrote
> Dear grass-users,
> After a full installation of "grass gis" and the download of the addon
> "r.massmov" through the user interface,
> I  do not manage to launch r.massmov. When I execute r.massmov, I become
> the error message :
> "Traceback (most recent call last):
>   File "C:\Program Files\GRASS GIS
> 7.2.1\gui\wxpython\gui_core\menu.py", line 174, in
> <lambda>
> self._btnRun.Bind(wx.EVT_BUTTON, lambda evt: self.Run())
> 7.2.1\gui\wxpython\gui_core\menu.py", line 235, in Run
> eval(handler)(event=None, cmd=data['command'].split())
> 7.2.1\gui\wxpython\lmgr\frame.py", line 892, in OnMenuCmd
> GUI(parent=self, giface=self._giface).ParseCommand(cmd)
> 7.2.1\gui\wxpython\gui_core\forms.py", line 2799, in
> ParseCommand
> raise gcmd.GException(e.value)
> core.gcmd
> GException
> Impossible de récupérer la description de l'interface pour
> la commande 'r.massmov'.
> Détails: C:\Program Files\GRASS GIS
> 7.2.1\extrabin\python.exe: can't open file 'r.massmov':
> [Errno 2] No such file or directory
> 7.2.1\gui\wxpython\gui_core\treeview.py", line 57, in
> <lambda>
> self._emitSignal(evt.GetItem(), self.itemActivated))
> 7.2.1\gui\wxpython\gui_core\treeview.py", line 162, in
> _emitSignal
> signal.emit(node=node, **kwargs)
> 7.2.1\etc\python\grass\pydispatch\signal.py", line 229, in
> emit
> dispatcher.send(signal=self, *args, **kwargs)
> 7.2.1\etc\python\grass\pydispatch\dispatcher.py", line 349,
> in send
> **named
> 7.2.1\etc\python\grass\pydispatch\robustapply.py", line 60,
> in robustApply
> return receiver(*arguments, **named)
> 7.2.1\gui\wxpython\gui_core\menu.py", line 178, in
> <lambda>
> self._tree.itemActivated.connect(lambda node:
> self.Run(node))
> ParseCommand
> core.gcmd
> GException
> [Errno 2] No such file or directory"
> Do you know what is the problem ? Thank for you help ! 😊
there seems to be a problem with the libgomp-1.dll.
libgomp is the GNU Offloading and Multi Processing Runtime Library.
please open a new ticket at https://trac.osgeo.org/grass and give following
information:
- winGRASS standalone installer or OSGeo4W-winGRASS
- 32bit or 64bit
- which version.
[1] https://gcc.gnu.org/onlinedocs/libgomp/
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/I-do-not-manage-to-launch-r-massmov-tp5324421p5324468.html
Sent from the Grass - Users mailing list archive at Nabble.com.
