[GRASS-user] Filling sinks w/ minimum slope
Ken Mankoff
mankoff at gmail.com
Tue Jun 20 06:24:09 PDT 2017
On 2017-06-20 at 08:45, Markus Metz <markus.metz.giswork at gmail.com> wrote:
> Negative values in the drainage direction should only occur at the
> borders of the current region and around NULL cells. Note that if you
> want internal sinks to be drained, you must not use the depression
> option.
I was not using depression option but I have determined that the mask I was using had a few NULLs in it that I was not aware of. I think this was the problem.
Thank you for assisting,
-k.
