[GRASS-user] calculate height above ground for a specific vertical angle of view
    frank
    frank.david at geophom.fr
    Thu Jun 22 23:51:34 PDT 2017
Le 21/06/2017 à 12:44, Frank David a écrit :
> Hello,
> I have calculated viewshed maps from one point of view at 2m height
> increasing the altitude above topography from 0 to 250m. So with
> r.series i can calculate the total visible height (sum of True in meter)
> or the total invisible height(sum of false in meter), or the vertical
> visible angle (angle-mode).
> I want now calculate the visible height (in metres) according to a
> specific vertical angle of view from my point of view.
> Witch method I could use to get effectively that result ?
> Thanks !
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
I think I have found the way to do it, if I find the trick to count the
number of raster where values are inside a range limit (-inf,myTarget).
Because I have one raster of vertical angle by meter.
I've tried r.series with range but I'have not found the way to count the
raster number processed in the range limit
Is anyone have an idea ?
Thanks for your help
