[GRASS-user] Setting layer transparency from a script
Laurent C.
lrntct at gmail.com
Sun Mar 12 16:31:18 PDT 2017
Hi Nikos,
What I would like is the possibility to set a percentage of opacity. But if
I understand well, it is what is doing pnmcomp.
Thanks for your appreciation.
Regards,
Laurent
On 11 Mar 2017 03:35, "Nikos Alexandris" <nik at nikosalexandris.net> wrote:
Laurent C.:
Hello,
> I'm using a Python script to generate maps for publication by setting
> GRASS_RENDER_FILE and running the different d.* commands. Is it
> possible to add opacity to some of the layers?
Dear Laurent,
not a direct answer, but you might want to read
<https://lists.osgeo.org/pipermail/grass-user/2016-March/073831.html>
Also, the r.out.png tool has a "-t Make NULL cells transparent" flag.
Kind regards and thank you for your excellent work I've seen elsewhere.
Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170312/af14e3ad/attachment.html>
