[GRASS-user] r.neighborhoodmatrix error message
Michele Zurlo
michele.zurlo at unimi.it
Mon Mar 13 04:09:28 PDT 2017
Hi Moritz.
First of all thank you for your very quick answer.
I tried both suggested solution. The first one, try to manually change the script, didn't work.
But luckily use OSGeo Live 10 is an option for me and I just finished to install the latest version and to download all the required add-ons.
Both r.neighborhoodmatrix and i.segment.uspo now work well :-)
Thank you again
Michele
On 07/03/17 17:55, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> Hi Michele !
> On 07/03/17 17:27, Michele Zurlo wrote:
> >Hi I'm Michele and this is my first e-mail in this mailing list and I
> >hope to find a little help :-)
> >I'm working to classify some UAV images and I would like to follow the
> >method proposed by Grippa et al. 2016
> ><http://proceedings.utwente.nl/367/1/Grippa-An%20Open-Source%20Semi-Automated%20Processing%20Chain%20For%20Urban%20OBIA%20Classification-28.pdf>
> >working with i.segment.uspo
> ><https://grass.osgeo.org/grass72/manuals/addons/i.segment.uspo.html>.
> >So I downloaded and installed the OSGEO Live 9.5 and from GRASS shell I
> >installed i.segment.uspo
> ><https://grass.osgeo.org/grass72/manuals/addons/i.segment.uspo.html> and
> >the required r.neighborhoodmatrix
> ><https://grass.osgeo.org/grass72/manuals/addons/r.neighborhoodmatrix.html>.
> >Everything went right but when I try to use i.segment.uspo
> ><https://grass.osgeo.org/grass72/manuals/addons/i.segment.uspo.html> I
> >get an error message because there is something wrong with
> >This is the error message retrieved trying to use r.neighborhoodmatrix
> ><https://grass.osgeo.org/grass72/manuals/addons/r.neighborhoodmatrix.html>:
> >Traceback (most recent call last):
> > File
> >"/home/user/.grass7/addons/scripts/r.neighborhoodmatrix",
> >line 137, in <module>
> > main()
> > File
> >line 123, in main
> > unique_neighbors_sorted =
> >gscript.natural_sort(unique_neighbors)
> >AttributeError: 'module' object has no attribute
> >'natural_sort'
> >I tried to re-install the module but I retrieved the same message.
> >Someone can help me?
> This sounds like OSGeo Live 9.5 contains a version of GRASS GIS that did not have this natural_sort in the GRASS Python scripting library, yet.
> Is using OSGeo Live 10 an option for you ? This contains GRASS 7.0.4 which is the first version that contains natural_sort as a utility function.
> Otherwise, it is quite easy to introduce it manually in the script. Copy the following into /home/user/.grass7/addons/scripts/r.neighborhoodmatrix, just before the "def cleanup():" line:
> def natural_sort(l):
> """Returns sorted strings using natural sort
> convert = lambda text: int(text) if text.isdigit() else text.lower()
> alphanum_key = lambda key: [convert(c) for c in re.split('([0-9]+)', key)]
> return sorted(l, key=alphanum_key)
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170313/f983c9a1/attachment.html>
