[GRASS-user] [vector attribute query]
Moritz Lennert
mlennert at club.worldonline.be
Thu Mar 16 05:37:03 PDT 2017
On 16/03/17 12:36, Ang Sherpa wrote:
> Hello users,
> Is it possible to query according to coordinates and return the value of
> desired column from attribute table as result.
> v.what allows to query the map, however, could not figure out how to
> choose the column in attribute table.
> Eg. In a world shape file having "population" as one of its column in
> attribute table.
> when 25.36258,85.236554 is entered in coordinates then it should return
> the population of that country in which the given coordinates belongs to.
> Any help will be much appreciated.
It depends on the language in which you are working.
In a bash shell, using the NC demo dataset, here's how you can get the
name of a specific county which is in the NAME column of the attribute
table:
eval $(v.what -ga boundary_county coordinates=498364.930178,229163.426556)
echo $NAME
In python, you can use parse_command to get a dictionary of results:
result = gscript.parse_command('v.what', flags='ga',
map='boundary_county', coordinates=[498364.930178,229163.426556])
result['NAME']
Moritz
