[GRASS-user] Slow import of GHSL
Nikos Alexandris nik at nikosalexandris.net
Fri Mar 17 03:02:30 PDT 2017
[gdal-dev removed from Cc]
Nikos A:
>>>> unfortunately, because I don't have a lot of free space :-/
Markus M:
>>> maybe because you forgot the enable compression ;-)
>> I should!
Markus N:
>Remember that you have to explicitly switch on the NULL compression:
>https://grass.osgeo.org/grass72/manuals/rasterintro.html#raster-compression
Thanks for this one too.  I guess we can't opt for a "sane" default NULL
compression. Can we? For future versions?
There are "out-of-date" versions of GRASS, in software repositories.  For example,
https://dl.fedoraproject.org/pub/epel/7/x86_64/g/, see for gdal and
grass.  So, this complicates thigns (compatibility).
Nikos
