[GRASS-user] GRASS, ordinal not in range(128)
Moritz Lennert
mlennert at club.worldonline.be
Sun Mar 19 05:42:59 PDT 2017
Le Sat, 18 Mar 2017 11:53:48 -0300,
Andres Solarte <e.andres.solartec at gmail.com> a écrit :
> Hello Markus,
> the first suggestion solved the problem
This sounds like there might be some issue handling the translation.
Probably warrants a bug report.
Moritz
> thank you so much, now it works :)
> Gracias Vero también a vos!!!
> Regards,
> Andrés.
> 2017-03-17 16:37 GMT-03:00 Markus Neteler <neteler at osgeo.org>:
> > Hi,
> > On Wed, Mar 15, 2017 at 12:59 PM, Andres Solarte
> > <e.andres.solartec at gmail.com> wrote:
> > > GRASS 7.3.svn (prueba):~ > t.register -i type=raster
> > > input=ndvi_andres maps=`g.list raster pattern=prueba_andres*
> > > separator=comma` start="2015-09-07" increment="1 days"
> > > Reuniendo información del mapa...
> > > ERROR: ascii,Definir tiempo absoluto válido para mapa
> > > <,25,26,ordinal not in range(128)
> > two suggestions:
> > 1. switch on the fly to English in the session, then run the last
> > command again:
> > export LANG=en_US
> > export LANGUAGE=en_US
> > export LC_MESSAGES=en_US
> > t.register ...
> > 2. if that also fails, change the debug level with
> > g.gisenv set=DEBUG=1 # or 2 or 3 ...
> > t.register ...
> > g.gisenv set=DEBUG=0
> > and see if you can find out from the output where it roughly
> > happens.
> > best
> > Markus
