[GRASS-user] [Process ended with error code -1073741515]
Helmut Kudrnovsky
hellik at web.de
Tue Mar 21 05:49:57 PDT 2017
Ang Sherpa wrote
> Module import into python script is working fine. However, when I tried to
> print out the g.region with
> gscript.run_command('g.region',raster='nep_drain',overwrite=True). It
> throws the following error.
> Process ended with non-zero return code -1073741515
some additional checks you may do:
- check if there are interfering/conflicting multiple python installations
on your system
- check if there are interfering/conflicting multiple gdal installations on
your system
- check if "download and install MS runtime binaries" during standalone
winGRASS installation procedure is activated.
this error seems to come from the underlying operating system.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Process-ended-with-error-code-1073741515-tp5313360p5313408.html
Sent from the Grass - Users mailing list archive at Nabble.com.
