[GRASS-user] Interpreting t.info metadata
Sören Gebbert soerengebbert at googlemail.com
Thu Mar 23 11:12:41 PDT 2017
You have 24 maps and therefore 24 minimum values, one for each map,
and 24 maximum values. t.info shows the minimums and maximums of these
values. The smallest minimum value of all 24 maps is 0.001, the
largest maximum value of all 24 maps is 3.01965.
Best regards
Soeren
2017-03-23 18:43 GMT+01:00 Rich Shepard <rshepard at appl-ecosys.com>:
>   t.info metadata for the STRDS of water accumulation over 23 days are:
> North-South resolution min:. 1.00003
> North-South resolution max:. 1.00003
> East-west resolution min:... 0.999846
> East-west resolution max:... 0.999846
> Minimum value min:.......... 0.001
> Minimum value max:.......... 0.001008
> Maximum value min:.......... 0.47729
> Maximum value max:.......... 3.01965
> Aggregation type:........... None
> Number of registered maps:.. 24
>   Input rainfall data for each day ranges from 0.0 mm/hr to 1.12 mm/hr. I
> want to learn what the min/min, min/max, max/min, and max/max values
> represent.
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
