[GRASS-user] Itzi results have one day lead from input data
Rich Shepard rshepard at appl-ecosys.com
Thu Mar 23 11:49:02 PDT 2017
On Thu, 23 Mar 2017, Laurent C. wrote:
> Is this t.info output taken from the STRDS created by Itzï?
Laurent,
   I assume so since the registered maps are Itzi output.
> The current version of Itzï does not record the initial state. So if you
> tell Itzï that the simulation starts at 2013-11-15 00:00:00 and the
> record_step is 24:00:00, then the first registered map will be at
> 2013-11-16 00:00:00.
   This is what Soeren wrote, too.
> However, the last record should be equal to the end_time given in the Itzï
> configuration file. If not, please fill-up an issue
> (https://bitbucket.org/itzi-model/itzi/issues)
   Here is the time portion of the parameter file:
[time]
start_time = 2013-11-15 00:00
duration = 600:00:00
record_step = 24:00:00
and the end turns out to be 2013-12-09 00:00.
Thanks,
Rich
