[GRASS-user] r.mapcalc: compare two maps
Sören Gebbert
soerengebbert at googlemail.com
Wed Mar 29 06:21:56 PDT 2017
The difference is computed for each pixel.
Just visualize the new map "mapdiff" of run r.univar mapdiff.
2017-03-28 22:23 GMT+02:00 Rich Shepard <rshepard at appl-ecosys.com>:
> I want to compare two raster maps for any differences. The r.mapcalc
> expression I used yielde no results ... unless getting the GRASS shell
> prompt means there are no differences.
> Command and result:
>> r.mapcalc "mapdiff = blocked_culvert - open_culvert"
> No differences? Wrong syntax?
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
