[GRASS-user] r.mapcalc: compare two maps [RESOLVED]
Laurent C.
lrntct at gmail.com
Thu Mar 30 11:14:08 PDT 2017
2017-03-30 12:09 GMT-06:00 Rich Shepard <rshepard at appl-ecosys.com>:
> On Thu, 30 Mar 2017, Rich Shepard wrote:
>> Would the process be to use v.edit on a copy (called 'stream') of the
>> culvert point map to generate a straight line between the two points? That
>> would provide the vector input r.carve wants.
> How do I add a line between two specific points using the vector digitizer
> in the GUI map display window?
> Clicking on one point, then on the other point does not show a line
> between the two points.
> Clicking on one point and dragging the cursor to the other point before
> releasing the button also does not display a line between the two points.
> Clue stick needed.
You need first to create a new vector map (or edit an existing one)
and select "digitize new line".
Laurent
