[GRASS-user] Problems with r.surf.contour
Markus Neteler neteler at osgeo.org
Thu Mar 30 13:11:25 PDT 2017
Dear Bianca,
On Thu, Mar 30, 2017 at 5:27 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Thu, Mar 30, 2017 at 3:48 PM, Bianca Federici <bianca.federici at unige.it>
>> The contour lines are quite coarse, and I can surely try to use other
>> interpolation methods... but the point is:
>> r.surf.contour works well???
> I don't think so.
Yes, there are much better methods than r.surf.contour.
See also here:
https://grasswiki.osgeo.org/wiki/Contour_lines_to_DEM
markusN
>> it's seems to me that no linear interpolation between two contour levels
>> is perfomed, in fact the slope is not constant between them but increase
>> until half the distance and then decrease, or viceversa, instead of being
>> constant.
> There are indeed strange patterns in the slope values between contour lines.
> The used distance to the second contour is not the shortest distance to the
> second contour, that is a bug. The distance calculation is unusual, it is
> not euclidean and not manhattan distance, no idea what kind of distance this
> is.
> Apart from that, I would not use linear interpolation to create a surface
> from contour lines but use one of the previously mentioned r.resamp.*
> modules. And r.surf.contour is incredibly slow.
> Markus M
