[GRASS-user] CHELSA climate data set
Helmut Kudrnovsky hellik at web.de
Tue May 2 12:45:25 PDT 2017
Veronica Andreo wrote
> Hi :)
> JFYI, CHELSA v1.2 is out
> 2017-02-07 15:43 GMT+01:00 Markus Neteler <
> neteler@
>> On Tue, Feb 7, 2017 at 3:32 PM, Markus Metz
> markus.metz.giswork@
> > wrote:
>> > Compared to GMTED, CHELSA extents further south to 90:0:0.5S which
>> conforms
>> > to the GMTED grid geometry. For CHELSA, however gdalinfo reports
>> > Pixel Size = (0.008333333300000,-0.008333333300000)
>> > while for GMTED, gdalinfo reports
>> > Pixel Size = (0.008333333333333,-0.008333333333333)
>> > The reason for the slightly smaller pixel size is most probably reduced
>> > floating point precision during creation of the CHELSA data.
>> from personal comm.:
>> They are currently investigating where the precision is cut in their
>> workflow (the upcoming V1.2 shall come with a related correction).
> Unfortunately they have not corrected the precision issue...
> gdalinfo CHELSA_temp_2_1979-2013_V1.2_land.tif
> Driver: GTiff/GeoTIFF
> Files: CHELSA_temp_2_1979-2013_V1.2_land.tif
> Size is 43200, 20880
> Origin = (-180.000138888850017,83.999860415150010)
> Corner Coordinates:
> Upper Left  (-180.0001389,  83.9998604) (180d 0' 0.50"W, 83d59'59.50"N)
> Lower Left  (-180.0001389, -90.0001389) (180d 0' 0.50"W, 90d 0' 0.50"S)
> Upper Right ( 179.9998597,  83.9998604) (179d59'59.49"E, 83d59'59.50"N)
> Lower Right ( 179.9998597, -90.0001389) (179d59'59.49"E, 90d 0' 0.50"S)
> Center      (  -0.0001396,  -3.0001392) (  0d 0' 0.50"W,  3d 0' 0.50"S)
> Band 1 Block=43200x1 Type=Float32, ColorInterp=Gray
>   NoData Value=-99999
> best,
> Vero
yes, AFAIK they're still working on it.
tested here ver.1.2 with r.in.gdal trunk and
-a
    Auto-adjustment for lat/lon
    Attempt to fix small precision errors in resolution and extents
it seems to give good results.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/CHELSA-climate-data-set-tp5284115p5319124.html
Sent from the Grass - Users mailing list archive at Nabble.com.
