[GRASS-user] CHELSA climate data set
Markus Metz markus.metz.giswork at gmail.com
Tue May 2 23:15:12 PDT 2017
On Tue, May 2, 2017 at 10:16 PM, Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi Helli,
> Yes, if you want the global map the -a flag plus the relaxed conditions
for the extent of global maps are fine...
> However, I wanted to also only import the region i'm working on and make
use of the -r flag in r.in.gdal... then the problems start... no
combination of -a, raster or align parameters in r.region give me the
correct region (either the resolution is wrong or the extent). My solution
so far is import the global map with r.in.gdal -a, then use r.mapcalc to
get the region I need... any other suggestion about better workflow is more
than welcome :)
Be aware that the -r flag of r.in.gdal aligns the current region to the
grid geometry of the input raster, i.e. the output might not match exactly
the current region. For CHELSA that means that not only the input
resolution is preserved, but also the 0.5 seconds shift to the West and
South.
Can you provide an example why you think that the grid geometry of the
imported raster is not correct?
Markus M
> best,
> Vero
> 2017-05-02 21:45 GMT+02:00 Helmut Kudrnovsky <hellik at web.de>:
>> Veronica Andreo wrote
>> > Hi :)
>> > JFYI, CHELSA v1.2 is out
>> > 2017-02-07 15:43 GMT+01:00 Markus Neteler <
>> > neteler@
>> >> On Tue, Feb 7, 2017 at 3:32 PM, Markus Metz
>> > markus.metz.giswork@
>> > > wrote:
>> >> > Compared to GMTED, CHELSA extents further south to 90:0:0.5S which
>> >> conforms
>> >> > to the GMTED grid geometry. For CHELSA, however gdalinfo reports
>> >> > Pixel Size = (0.008333333300000,-0.008333333300000)
>> >> > while for GMTED, gdalinfo reports
>> >> > Pixel Size = (0.008333333333333,-0.008333333333333)
>> >> > The reason for the slightly smaller pixel size is most probably
reduced
>> >> > floating point precision during creation of the CHELSA data.
>> >> from personal comm.:
>> >> They are currently investigating where the precision is cut in their
>> >> workflow (the upcoming V1.2 shall come with a related correction).
>> > Unfortunately they have not corrected the precision issue...
>> > gdalinfo CHELSA_temp_2_1979-2013_V1.2_land.tif
>> > Driver: GTiff/GeoTIFF
>> > Files: CHELSA_temp_2_1979-2013_V1.2_land.tif
>> > Size is 43200, 20880
>> > Origin = (-180.000138888850017,83.999860415150010)
>> > Corner Coordinates:
>> > Upper Left  (-180.0001389,  83.9998604) (180d 0' 0.50"W, 83d59'59.50"N)
>> > Lower Left  (-180.0001389, -90.0001389) (180d 0' 0.50"W, 90d 0' 0.50"S)
>> > Upper Right ( 179.9998597,  83.9998604) (179d59'59.49"E, 83d59'59.50"N)
>> > Lower Right ( 179.9998597, -90.0001389) (179d59'59.49"E, 90d 0' 0.50"S)
>> > Center      (  -0.0001396,  -3.0001392) (  0d 0' 0.50"W,  3d 0' 0.50"S)
>> > Band 1 Block=43200x1 Type=Float32, ColorInterp=Gray
>> >   NoData Value=-99999
>> > best,
>> > Vero
>> yes, AFAIK they're still working on it.
>> tested here ver.1.2 with r.in.gdal trunk and
>> -a
>>     Auto-adjustment for lat/lon
>>     Attempt to fix small precision errors in resolution and extents
>> it seems to give good results.
>> best regards
>> Helmut
>> View this message in context:
http://osgeo-org.1560.x6.nabble.com/CHELSA-climate-data-set-tp5284115p5319124.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170503/594de2ff/attachment.html>
