[GRASS-user] t.create error: Unable to connect to psycopg2 database: newdb
RichardCooper
richtcooper at hotmail.com
Sat May 6 06:45:27 PDT 2017
Replying somewhat late to my query last year, but I'm still getting the same
error with regard to using t.create with a PostgreSQL database connection
with GRASS 7.2.0
t.connect driver=pg database=grasscldb
(Sat May 6 20:36:01 2017) Command finished (0 sec)
(Sat May 6 20:36:08 2017)
t.connect -p driver=pg database=grasscldb
driver:pg
database:grasscldb
(Sat May 6 20:36:08 2017) Command finished (0 sec)
t.create --overwrite output=cahpc_test_strd temporaltype=relative
semantictype=max title=title test description=descr test
ERROR: Unable to connect to psycopg2 database: grasscldb
Exception: "missing "=" after "grasscldb" in connection info string
Please use t.connect to set a read- and writable temporal database backend
(Sat May 6 20:37:36 2017) Command finished (0 sec)
System Info
GRASS version: 7.2.0
GRASS SVN revision: exported
Build date: 2017-04-07
Build platform: x86_64-pc-linux-gnu
GDAL: 1.11.2
PROJ.4: 4.9.0
GEOS: 3.4.2
SQLite: 3.8.2
Python: 2.7.6
wxPython: 2.8.12.1
Platform: Linux-3.13.0-95-generic-x86_64-with-LinuxMint-17.1-rebecca
View this message in context: http://osgeo-org.1560.x6.nabble.com/t-create-error-Unable-to-connect-to-psycopg2-database-newdb-tp5296563p5319598.html
Sent from the Grass - Users mailing list archive at Nabble.com.
