[GRASS-user] Error on start up - session manager - ubuntu 16.04
Lars Dalby lars.dalby at gmail.com
Tue May 9 23:11:05 PDT 2017
Hi Anna
Thank you for your feedback.
No, as far as I can tell, GRASS is working just fine, but I've only
imported and display a single vector file.
If it is a harmless error message, I'll just ignore it and move on.
Cheers,
Lars
On Wed, May 10, 2017 at 4:23 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Tue, May 9, 2017 at 3:16 AM, Lars Dalby <lars.dalby at gmail.com> wrote:
> > Dear list
> > When starting GRASS 7.2.1 on Ubuntu 16.04 I got this error message on
> start
> > up:
> > "Debug: Failed to connect to session manager: SESSION_MANAGER environment
> > variable not defined"
> Does it actually cause any problems? This happens on Ubuntu (not sure
> why), but it should be harmless.
> > Then searching the web for solutions I found this thread:
> > http://osgeo-org.1560.x6.nabble.com/SESSION-MANAGER-
> environment-variable-not-defined-td5181059.html
> > I tried "export SESSION_MANAGER=1" as suggested in the thread which
> resulted
> > in a new error on start up:
> > "_IceTransOpen: Unable to Parse address 1 08:49:34 AM: Debug: Failed to
> > connect to session manager: Could not open network socket"
> > At this point I decided that it was time I admitted that I don't know
> what
> > I'm doing! :-)
> > Can anybody help me sort out this issue?
> > I have python 3.5.2 and python 2.7.12 installed. Only in python 2.7.12
> does
> > wx appear to be available and in version wx-3.0-gtk2.
> GRASS doesn't have official Python 3 support. There has just been
> released wxPython 4.0 which has Python 3 support, but porting GRASS is
> work in progress.
> Anna
> > When starting GRASS from the terminal I see the above mentioned error but
> > the GRASS gui starts and I can open a location.
> > Best
> > Lars
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170510/e6caefc7/attachment.html>
