[GRASS-user] Problems launching GRASS 7.2
Anna Petrášová
kratochanna at gmail.com
Wed May 10 08:36:00 PDT 2017
On Wed, May 10, 2017 at 3:31 AM, alonso <alonsarp at um.es> wrote:
> Hi:
> I have a problem when launching GRASS 7.2 that I compiled it in a Debian 8.6
what does
g.extension -ag
give you when you run it from the terminal in grass session?
> machine with apparently no problem:
> My configure call is:
> CFLAGS="-g -Wall -Werror-implicit-function-declaration -fno-common -Wextra
> -Wunused" \
> CXXFLAGS="-g -Wall" \
> ./configure \
> --prefix=/usr/local \
> --with-gdal \
> --with-proj --with-proj-share=/usr/share \
> --with-glw --with-nls --with-readline \
> --with-cxx --enable-largefile --enable-shared \
> --with-freetype \
> --with-freetype-includes=/usr/include/freetype2 \
> --with-sqlite --with-cairo \
> --with-python=/usr/bin/python-config \
> --with-geos=/usr/local/bin/geos-config \
> --with-blas \
> --with-lapack --with-lapack-includes=/usr/lib/lapack \
> --with-liblas=yes \
> --with-netcdf=/usr/bin/nc-config --with-odbc=yes \
> --with-openmp=yes --with-pthread=yes --with-postgres=yes \
> --with-postgres-includes=/usr/local/pgsql/include \
> --with-postgres-libs=/usr/local/pgsql/lib \
> --with-tcltk-includes=/usr/include/tcl8.6/ \
> --with-x --x-libraries=/usr/lib/x86_64-linux-gnu \
> --with-wxwidgets --libdir=/usr/local/lib --includedir=/usr/local/include
> and the answer is:
> GRASS is now configured for: x86_64-pc-linux-gnu
> Source directory: /usr/local/grass-7.2.1
> Build directory: /usr/local/grass-7.2.1
> Installation directory: ${prefix}/grass-7.2.1
> Startup script in directory:${exec_prefix}/bin
> C compiler: gcc -g -Wall
> -Werror-implicit-function-declaration -fno-common -Wextra -Wunused
> C++ compiler: c++ -g -Wall
> Building shared libraries: yes
> OpenGL platform: X11
> MacOSX application: no
> MacOSX architectures:
> MacOSX SDK:
> BLAS support: yes
> BZIP2 support: no
> C++ support: yes
> Cairo support: yes
> DWG support: no
> FFTW support: yes
> FreeType support: yes
> GDAL support: yes
> GEOS support: yes
> LAPACK support: yes
> Large File support (LFS): yes
> libLAS support: yes
> MySQL support: no
> NetCDF support: yes
> NLS support: yes
> ODBC support: yes
> OGR support: yes
> OpenCL support: no
> OpenGL support: yes
> OpenMP support: yes
> PDAL support: no
> PNG support: yes
> POSIX thread support: yes
> PostgreSQL support: yes
> Readline support: yes
> Regex support: yes
> SQLite support: yes
> TIFF support: yes
> X11 support: no
> It compiles without any problem and no errors are reported.
> But when I try to run the program I have this python error and, although the
> command line interface works perfectly, I am not able to access the python
> graphical interface.
> GRASS 7.2.1 (CursoGRASS):~ > Traceback (most recent call last):
> File "/usr/local/grass-7.2.1/gui/wxpython/wxgui.py", line 158, in <module>
> sys.exit(main())
> File "/usr/local/grass-7.2.1/gui/wxpython/wxgui.py", line 145, in main
> app = GMApp(workspaceFile)
> File "/usr/local/grass-7.2.1/gui/wxpython/wxgui.py", line 48, in __init__
> wx.App.__init__(self, False)
> File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py", line
> 8628, in __init__
> self._BootstrapApp()
> 8196, in _BootstrapApp
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> File "/usr/local/grass-7.2.1/gui/wxpython/wxgui.py", line 92, in OnInit
> workspace=self.workspaceFile)
> File "/usr/local/grass-7.2.1/gui/wxpython/lmgr/frame.py", line 131, in
> __init__
> self._moduleTreeBuilder = LayerManagerModuleTree()
> File "/usr/local/grass-7.2.1/gui/wxpython/lmgr/menudata.py", line 66, in
> __init__
> self, filename, expandAddons=expandAddons)
> File "/usr/local/grass-7.2.1/gui/wxpython/core/menutree.py", line 67, in
> __init__
> expAddons(xmlTree)
> File "/usr/local/grass-7.2.1/gui/wxpython/core/toolboxes.py", line 364, in
> expandAddons
> _expandAddonsItem(root)
> File "/usr/local/grass-7.2.1/gui/wxpython/core/toolboxes.py", line 547, in
> _expandAddonsItem
> addons = _getAddons()
> File "/usr/local/grass-7.2.1/gui/wxpython/core/toolboxes.py", line 507, in
> _getAddons
> output = gcore.read_command('g.extension', quiet=True, flags='ag')
> File "/usr/local/grass-7.2.1/etc/python/grass/script/core.py", line 458,
> in read_command
> process = pipe_command(*args, **kwargs)
> File "/usr/local/grass-7.2.1/etc/python/grass/script/core.py", line 433,
> in pipe_command
> return start_command(*args, **kwargs)
> File "/usr/local/grass-7.2.1/etc/python/grass/script/core.py", line 377,
> in start_command
> return Popen(args, **popts)
> File "/usr/local/grass-7.2.1/etc/python/grass/script/core.py", line 74, in
> __init__
> subprocess.Popen.__init__(self, args, **kwargs)
> File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
> errread, errwrite)
> File "/usr/lib/python2.7/subprocess.py", line 1335, in _execute_child
> raise child_exception
> OSError: [Errno 2] No such file or directory
> Any hints?
> Thanks in advance.
> Paco
> Francisco Alonso Sarría
> Instituto del Agua y del Medio Ambiente
> Universidad de Murcia
> E-30001- Murcia
> Telfno: +34 868888695
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
