[GRASS-user] Is there a command-line only version for Linux available?
Bartolomei.Chris Bartolomei.Chris at ensco.com
Fri May 12 00:05:06 PDT 2017
Thanks for the info Martin  :)
I'll look into the grass-core and see if somehow I can build it for CentOS... I've only found grass, grass-libs, and grass-devel rpms for CentOS....
as to the G6 tools; that's what the people I'm doing this for have ... and there's no upgrading to 7. Gotta work with what I have available... (ugh)... nothing like a challenge, eh?
Chris
Sent: Wednesday, May 10, 2017 10:49:14 PM
To: Bartolomei.Chris
Cc: grass-user
Subject: Re: [GRASS-user] Is there a command-line only version for Linux available?
2017-05-11 2:51 GMT+02:00 Bartolomei.Chris <Bartolomei.Chris at ensco.com>:
> I have a need to use the GRASS tools (r.mapcalc, v.clean, r.to.vect, and a few others probably) on a Linux system (CentOS 6.7) that has no GUI software installed (it's a number-cruncher in a restricted environment) ... the interface is command-line only and it has a minimal OS build.  I know I can use the GRASS tools via scripts without starting GRASS but can I use them without installing all of GRASS? I'm going through what I need to install GRASS and the list of software dependencies is rather long ... is there a command-line only version around without all of the graphical software overhead? At the moment I'm limited to using GRASS 6.4.4 tools ...
I don't know about CestOS, but Debian/Ubuntu packages are separated.
You would need to install just grass-core package in your case.
BTW, why limited to G6 tools? Martin
Martin Landa
https://urldefense.proofpoint.com/v2/url?u=http-3A__geo.fsv.cvut.cz_gwiki_Landa&d=CwIFaQ&c=DsZY2bea7iNIzyp-7sZ0t0F2UfNQZUfZhEPCv_2wBI0&r=O31ltou6ygJL2Y01kQyNJJD2kiILIsbyz2V0Hn4lFUY&m=2VHUmmTKLOFZWgav8Z_UsZUuLf4cnqZvqY7CPrMaj5E&s=Lmp9bw-ex2KXujpTNJ6IEnY1_0pop36ZWoyOAG720XE&e=
https://urldefense.proofpoint.com/v2/url?u=http-3A__gismentors.cz_mentors_landa&d=CwIFaQ&c=DsZY2bea7iNIzyp-7sZ0t0F2UfNQZUfZhEPCv_2wBI0&r=O31ltou6ygJL2Y01kQyNJJD2kiILIsbyz2V0Hn4lFUY&m=2VHUmmTKLOFZWgav8Z_UsZUuLf4cnqZvqY7CPrMaj5E&s=dUkRVvC0bC5KTXqnxtPqPMIrn013MteIVTwaT5Nwz_M&e=
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
