[GRASS-user] Downloading EuroLST data
Nikos Alexandris
nik at nikosalexandris.net
Fri May 12 02:41:32 PDT 2017
* Markus Neteler <neteler at osgeo.org> [2017-05-11 23:31:46 +0200]:
>Hi Nikos,
>On Thu, May 11, 2017 at 5:40 PM, Nikos Alexandris
><nik at nikosalexandris.net> wrote:
>> Dear list,
>> (EuroLST authors in Cc)
>> is there documented access to EuroLST data via something like
>> r.in.wms url=http://geodati.fmach.it/production/ows_europe_lst
>> layers=eurolst_clim_bio01 srs=3035 ... urlparams='time=2012-1-1'
>Yes:
>r.in.wms url="http://geodati.fmach.it/production/ows_europe_lst" -c |
>grep Abstract
> <Abstract>Bioclim data derived from gap-filled MODIS-LST (EuroLST)</Abstract>
> <Abstract>Annual mean temperature (deg C * 10)</Abstract>
> <Abstract>Mean diurnal range as the mean of monthly (max temp
>- min temp) (deg C * 10)</Abstract>
> <Abstract>Isothermality (BIO2/BIO7 * 100)</Abstract>
> <Abstract>Temperature Seasonality (standard deviation * 100)</Abstract>
> <Abstract>Max Temperature of Warmest Month (deg C * 10)</Abstract>
> <Abstract>Min Temperature of Coldest Month (deg C * 10)</Abstract>
> <Abstract>Temperature Annual Range (BIO5 - BIO6) (deg C * 10)</Abstract>
> <Abstract>Mean Temperature of Warmest Quarter (deg C * 10)</Abstract>
> <Abstract>Mean Temperature of Coldest Quarter (deg C * 10)</Abstract>
The capabilities work fine. Getting/reading in data isn't though.
>> Wonder also if there is access to daily/monthly temperature data (such as
>> min, mean, max).
>That's not available since the underlying GRASS GIS data are > 15TB.
>Not possible to put online given the resources we had :-)
Got it. Would you consider to share access to at least of a year of
data?
Thanks for the response,
Nikos
