[GRASS-user] more plotting errors
Anna Petrášová kratochanna at gmail.com
Thu May 18 08:49:37 PDT 2017
On May 18, 2017 9:15 AM, "Tyler Smith" <tyler at plantarum.ca> wrote:
On Thu, May 18, 2017, at 12:28 AM, Anna Petrášová wrote:
> Are you sure this is the feature causing the error? This seems to be
> ok. Can you also post the output of
> grass.vector_what(map='Obs_20170329 at PERMANENT',
> coord=(1548324.30568,12154706.4547),  distance=100)
I'm not actually sure which feature caused the problem, now that you
mention it. I tried again with just that map:
    [start grass]
    d.mon start=wx0
    d.vect map=Obs_20170329 at PERMANENT
And it seems to work fine.
So I added the other layers one at a time to figure out which was the
problem:
d.vect map=counties at PERMANENT type=boundary
d.vect map=usa type=boundary
And now I find the problem is actually the usa map. This is an outline
of the USA. So I retried the commands from before using this map:
v.what -j map=usa coordinates=1698426.136563,12132061.925937
{"Coordinates": {"East": "1698426.136563", "North": "12132061.925937"},
"Maps":
[{"Map": "usa",
"Mapset": "PERMANENT"}
This output seems to be ok, it shouldn't cause any problems. Perhaps you
need to send us the link to your data with the exact command to reproduce
it.
That sort of makes sense, as the coordinates are outside of the
boundaries of the usa. But in that case v.what.vect should just return
'nothing found'? Does the output indicate something wrong with this map?
Thanks again,
Tyler
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170518/971b6148/attachment-0001.html>
