[GRASS-user] v.to.db area calculations
James Duffy james.philip.duffy at gmail.com
Fri May 19 00:39:14 PDT 2017
Hello,
Thanks for the reply. I don't have SAGA or PostGIS set up at the moment.
(have sent Stefan the shapefile off-list).
Moritz - I know that the QGIS value is true. The polygon has been drawn
over a feature on a raster image (which I know is correct in its
dimensions).
Thanks
James
On 19 May 2017 at 08:36, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 18/05/17 18:41, Blumentrath, Stefan wrote:
>> Hi James,
>> QGIS uses a ellipsoidal area measurement, while GRASS (like most of the
>> other GIS) uses a Cartesian measurement (others, please correct me if that
>> is not the case in WGS84).
>> See amongst others:
>> https://issues.qgis.org/issues/12057 and
>> https://issues.qgis.org/issues/14675
>> Would you mind comparing area measurement of a third software (SAGA,
>> PostGIS, ...)?
> I would suggest making tests with polygons of which you know the area
> (e.g. simple squares to begin with)
> Moritz
*James Duffy*
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170519/ad1390ad/attachment.html>
