[GRASS-user] FileGDB has 3 layers, only first imported
Rich Shepard rshepard at appl-ecosys.com
Wed Nov 1 11:06:38 PDT 2017
On Wed, 1 Nov 2017, Helmut Kudrnovsky wrote:
> What does ogrinfo say?
Helmut,
Had to open data source read-only.
INFO: Open of `NHDMajor.gdb/'
       using driver `OpenFileGDB' successful.
Layer name: NHD_MajorStreams
Geometry: 3D Measured Multi Line String
Feature Count: 76935
Extent: (588224.643635, -40611.889317) - (2875451.289850, 1832652.018517)
Layer SRS WKT:
PROJCS["NAD83(HARN) / Washington South (ftUS)",
     GEOGCS["NAD83(HARN)",
         DATUM["NAD83_High_Accuracy_Reference_Network",
             SPHEROID["GRS 1980",6378137,298.257222101,
                 AUTHORITY["EPSG","7019"]],
             TOWGS84[0,0,0,0,0,0,0],
             AUTHORITY["EPSG","6152"]],
         PRIMEM["Greenwich",0,
             AUTHORITY["EPSG","8901"]],
         UNIT["degree",0.0174532925199433,
             AUTHORITY["EPSG","9122"]],
         AUTHORITY["EPSG","4152"]],
     PROJECTION["Lambert_Conformal_Conic_2SP"],
     PARAMETER["standard_parallel_1",47.33333333333334],
     PARAMETER["standard_parallel_2",45.83333333333334],
     PARAMETER["latitude_of_origin",45.33333333333334],
     PARAMETER["central_meridian",-120.5],
     PARAMETER["false_easting",1640416.667],
     PARAMETER["false_northing",0],
     UNIT["US survey foot",0.3048006096012192,
         AUTHORITY["EPSG","9003"]],
     AXIS["X",EAST],
     AXIS["Y",NORTH],
     AUTHORITY["EPSG","2927"]]
FID Column = OBJECTID
Geometry Column = Shape
Permanent_Identifier: String (40.0) NOT NULL
FDate: DateTime (0.0) NOT NULL
Resolution: Integer (0.0) NOT NULL
GNIS_ID: String (10.0)
GNIS_Name: String (65.0)
LengthKM: Real (0.0)
ReachCode: String (14.0)
FlowDir: Integer (0.0) NOT NULL DEFAULT 0
WBArea_Permanent_Identifier: String (40.0)
FType: Integer (0.0) NOT NULL DEFAULT 460
FCode: Integer (0.0)
MainPath: Integer (0.0) NOT NULL DEFAULT 0
InNetwork: Integer (0.0) DEFAULT 1
VisibilityFilter: Integer (0.0) NOT NULL DEFAULT 0
Enabled: Integer(Int16) (0.0) DEFAULT 1
StreamOrder: Integer (0.0)
Shape_Length: Real (0.0)
Layer name: NHD_MajorAreas
Geometry: 3D Multi Polygon
Feature Count: 1485
Extent: (575544.125339, -221262.260342) - (2835065.755869, 1756831.324202)
Layer SRS WKT:
     AXIS["X",EAST],
     AXIS["Y",NORTH],
AreaSqKm: Real (0.0)
Elevation: Real (0.0)
Shape_Area: Real (0.0)
Layer name: NHD_MajorWaterbodies
Feature Count: 253
Extent: (587974.003621, 43717.982427) - (2691814.264464, 1862037.945440)
Layer SRS WKT:
     AXIS["X",EAST],
     AXIS["Y",NORTH],
FType: Integer (0.0) NOT NULL DEFAULT 390
> What is your cmd ?
   ~/data/grassdata/WashingtonHARM/ (after re-projection) and
~/data/grassdata/hydrography/ for import.
Rich
