[GRASS-user] Large import runs out of memory
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Thu Nov 2 01:13:11 PDT 2017
Hi Rich,
Please try GRASS_VECTOR_LOWMEM environment variable:
GRASS_VECTOR_LOWMEM
[vectorlib]
If the environment variable GRASS_VECTOR_LOWMEM exists, memory consumption will be reduced when building vector topology support structures. Recommended for creating large vectors.
See: https://grass.osgeo.org/grass72/manuals/variables.html
Cheers
Stefan
-----Original Message-----
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Rich Shepard
Sent: onsdag 1. november 2017 23.51
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] Large import runs out of memory
While trying to import (v.in.ogr) a large landuse .shp file grass gave up because it could not find 11+M (or G, I don't recall which) of memory. This desktop has 4G RAM installed and a 15G swap file. My builds are configured with largefile enabled. Are there other options that would allow grass to see and use the available swap space on the disk?
Rich
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
