[GRASS-user] were is grass looking for the input tif - r.viewshed run from bash script
Markus Neteler
neteler at osgeo.org
Thu Nov 2 01:38:08 PDT 2017
On Nov 2, 2017 6:45 AM, "karsten" <karsten at terragis.net> wrote:
> I am trying to run r.viewshed from a bash script on ubuntu following
> instruction on https://grasswiki.osgeo.org/wiki/GRASS_and_Shell "GRASS
Batch
> jobs". I got an error that my input tif file is not found.
> I tried specifying the full path to file but get then the Error Illegal
> filename
</var/www/mapdata/ilpoe/layers/results/dem30m_cut_852af91d4fe5fd938fa57893e5
> 991dfe.tif> Character </> not allowed.
> My 3 line script is below:
> export GRASS_MESSAGE_FORMAT=plain
> g.region n=6446299.8941608080640435 s=5942051.4022588636726141
> w=779220.9745125266490504 e=1224529.8597663976252079 res=30
> r.viewshed -b input="/var/www/results/dem30m.tif"
> output="/var/www/results/vis.tif"
You need to import or register the map first. Likewise for the export.
See for an example
https://grass.osgeo.org/grass72/manuals/r.external.html#processing-workflow-without-data-import-and-export
Best
Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171102/c7abaad6/attachment-0001.html>
