[GRASS-user] Large import runs out of memory
Martin Landa
landa.martin at gmail.com
Thu Nov 2 14:01:49 PDT 2017
2017-11-02 21:33 GMT+01:00 Rich Shepard <rshepard at appl-ecosys.com>:
> Failed to run command 'd.vect map=landuse10 at PERMANENT display=shape,zcoor
> width=1'. Details:
> GRASS_INFO_WARNING(1214,1): Vector map is not 3D. Unable to display
> z-coordinates.
> GRASS_INFO_END(1214,1)
> GRASS_INFO_ERROR(1214,2): Rendering failed GRASS_INFO_END(1214,2)
> It is a 2D land use layer so grass should not look for z-coordinates.
> Where do I look to see what in the imported map suggests there are
> elevations to display?
so why do you use display=zcoor ? Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
