[GRASS-user] Importing FileGDB with FIPS code [RESOLVED]
Helmut Kudrnovsky
hellik at web.de
Sat Nov 4 08:27:45 PDT 2017
Rich Shepard wrote
> On Fri, 3 Nov 2017, Helmut Kudrnovsky wrote:
>> What does ogrinfo tells about the data?
> Helmut,
> Had to open data source read-only.
> INFO: Open of `WQ_StandardsNHD_External.gdb/'
> using driver `OpenFileGDB' successful.
> Layer name: WQStandards_BeneficialUseDesignations
> Geometry: Multi Line String
> Feature Count: 764329
> Extent: (607675.393548, 81930.638752) - (2554273.406512, 1355726.104279)
> Layer SRS WKT:
> PROJCS["NAD_1983_HARN_StatePlane_Washington_South_FIPS_4602_Feet",
> GEOGCS["GCS_North_American_1983_HARN",
> DATUM["NAD83_High_Accuracy_Reference_Network",
> SPHEROID["GRS_1980",6378137.0,298.257222101]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],
> PROJECTION["Lambert_Conformal_Conic_2SP"],
> PARAMETER["False_Easting",1640416.666666667],
> PARAMETER["False_Northing",0.0],
> PARAMETER["Central_Meridian",-120.5],
> PARAMETER["Standard_Parallel_1",45.83333333333334],
> PARAMETER["Standard_Parallel_2",47.33333333333334],
> PARAMETER["Latitude_Of_Origin",45.33333333333334],
> UNIT["Foot_US",0.3048006096012192]]
> Question: ogrinfo calls the driver OpenFileGDB while the GUI driver
> list
> changed that to ESRI FileGDB. Why?
>> As Markus M. already mentioned in another thread, you can create a
>> location
>> based upon the SRS information of your data by v.in.ogr.
> And this is what I tried, using the GUI. I don't find yesterday's GUI
> attempt in the .bash_history file and I don't remmber the error message.
> Using the CLI, v.in.ogr works when I provide a location.
> For years I used only the CLI; Markus N. a few years ago suggested I
> use the GUI
> and I have been using that. While I can return to using only the CLI, that
> will not help development of 7.3; instead, when the GUI fails (as it did
> with this FileGDB I'll immediately use the command line. When the latter
> is
> successful I'll report the difference as a needed examination of the GUI.
> Regards,
> Rich
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
regarding options and flags of GRASS module commands, there is no difference
between GUI and CLI.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
