[GRASS-user] GRASS-way to delete points from a map and attribute table
Johannes Radinger
johannesradinger at gmail.com
Thu Nov 9 02:25:25 PST 2017
Indeed, finally I also used a combination of v.edit to remove the point
from the map and db.execute ("DELETE FROM my_point_map WHERE cat IN
(1,2,3)") to delete the entries from the attribute table.
/Johannes
On Thu, Nov 9, 2017 at 10:27 AM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> So, removing records from the attribute table would be a job for
> db.execute of db.select I guess…
> *From:* Johannes Radinger [mailto:johannesradinger at gmail.com]
> *Sent:* torsdag 9. november 2017 10.17
> *To:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> *Cc:* GRASS user list <grass-user at lists.osgeo.org>
> *Subject:* Re: [GRASS-user] GRASS-way to delete points from a map and
> attribute table
> Dear Stefan,
> thanks for the tip, but as said I tried already v.edit but somehow this
> tools does not modify the attribute table (or do I miss something here?)
> /Johannes
> On Thu, Nov 9, 2017 at 10:10 AM, Stefan Blumentrath <
> Did you try v.edit:
> https://grass.osgeo.org/grass72/manuals/v.edit.html
> Cheers
> Stefan
> *From:* grass-user [mailto:grass-user-bounces at lists.osgeo.org] *On Behalf
> Of *Johannes Radinger
> *Sent:* torsdag 9. november 2017 10.04
> *To:* GRASS user list <grass-user at lists.osgeo.org>
> *Subject:* [GRASS-user] GRASS-way to delete points from a map and
> attribute table
> Hi,
> what would be the most GRASS-like way to delete several points from a
> points vector map.
> I know the specific cats of the points I would like to delete (10 of
> 200000) and I want to delete the points from the map and, of course, also
> from the corresponding attribute table. I already tried v.edit but here the
> points are not deleted from the attribute table. I could also use v.extract
> with the reverse flag, however this requires to define a new output map
> (which I would like to avoid if possible). Any straight forward way in
> GRASS?
> /Johannes
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171109/80bdcdc7/attachment.html>
