[GRASS-user] Calculating cost to port
Daniel Victoria
daniel.victoria at gmail.com
Fri Nov 10 08:03:45 PST 2017
Hi list,
I want to calculate a cost of getting from any cell in my raster to some
ports, considering roads network, and I though r.cost could solve this.
What I have is:
1) Cost raster map with cost per cell (10 for normal cells, 1 if it's a
road)
2) vector map containing several ports
3) start_raster has the same extent of the cost raster, but all cells == 1
This is the command I'm using
r.cost input=cost_map output=cum_cost stop_points=ports
start_raster=my_region
However, my results is a map will all values equal zero. Is it because the
stop_points in ports lay inside my start_raster? Thus r.cost reaches the
stop point right from the start?
My final result should be a map of distance to ports considering the roads
network.
Cheers
Daniel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171110/67b3674b/attachment-0001.html>
