[GRASS-user] r.stream.extract error
Giuseppe Amatulli
giuseppe.amatulli at gmail.com
Thu Nov 16 13:51:07 PST 2017
Hi Markus M.
I was testing the r.stream.extract for 2 tiff
1) 80040 x 72870 = 5,832,514,800 i got the stream results - no error
2) 80490 x 142690 = 11,485,118,100 i got the following error
A* Search...
0..2../var/spool/slurmd/job6514787/slurm_script: line 80: 28925 Bus error
r.stream.extract elevation=elv accumulation=upa threshold=0.5
depression=dep direction=dir stream_raster=stream memory=45000 --o --verbose
Do you think that is something with the slurm ram limitation or is
something with the r.extract.stream?
If the the stream output have a number of stream segments larger than
2,147,483,647 what is happen?
Do I get an error or all the value larger than 2,147,483,647 are just
rounded to 2,147,483,647 ?
Moreover, if use the stream obtain from option 1) and I use the stream as
input for the r.stream.basins
I got the following error
reading raster map <stream>...
0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45../var/spool/slurmd/job6514788/slurm_script:
line 82: 17687 Bus error
/gpfs/home/fas/sbsc/ga254/.grass7/addons/bin/r.stream.basins -l
stream_rast=stream direction=dir
is this something that need to be fixed in r.stream.basins, or should i
think that is due to other problems
Thank you
Giuseppe
On 10 November 2017 at 11:21, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Nov 1, 2017 at 10:12 PM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
> > On Wed, Nov 1, 2017 at 7:15 PM, Giuseppe Amatulli
> > <giuseppe.amatulli at gmail.com> wrote:
> >> Thanks Markus!!
> >> I will test and I will let you know how it works.
> > Your feedback is very helpful!
> >> I have few more questions
> >> 1) now how much is the upper limit matrix cell number that
> >> r.stream.extract can handle?
> > About 1.15e+18 cells.
> > Another limitation is the number of detected stream segments. This must
> not
> > be larger than 2,147,483,647 streams,
> (Added as a note to
> https://grasswiki.osgeo.org/wiki/GRASS_GIS_Performance#Some_benchmarks
> best,
> markusN
Giuseppe Amatulli, Ph.D.
Research scientist at
Yale School of Forestry & Environmental Studies
Yale Center for Research Computing
Center for Science and Social Science Information
New Haven, 06511
Teaching: http://spatial-ecology.net
Work: https://environment.yale.edu/profile/giuseppe-amatulli/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171116/999de17e/attachment.html>
