[GRASS-user] making sense of r.reclass.area
Ken Mankoff
mankoff at gmail.com
Mon Nov 20 08:49:46 PST 2017
Hi Markus,
On 2017-11-17 at 14:09, Markus Metz <markus.metz.giswork at gmail.com> wrote:
> OK, I understand now. With method=rmarea, r.reclass converts the
> raster clumps to vector areas. That single cell in your example below,
> that either belongs to the larger clump 1 (with -d) or forms a
> separate clump 2 (without -d) will always be a separate small vector
> area (topology or not does not matter here) and thus will always be
> removed independent of the 2-cell clump. The vector approach is thus
> not working here as expected.
Thanks for looking into this and explaining. I'll open a documentation bug on Trac.
> Incidentally I have added a minsize option to r.clump in GRASS 7.4 which
> should work as expected. Try to use r.clump minsize=X (in number of cells)
> instead of r.reclass.area method=rmarea mode=lesser.
Between this and mapcalc area() function in 7.3 I need to find a way use more cutting-edge GRASS versions than 7.2.2 even though I'm on OS X.
-k.
