[GRASS-user] scale error for each pixel
Moritz Lennert
mlennert at club.worldonline.be
Tue Nov 21 00:26:55 PST 2017
On 20/11/17 21:20, Ken Mankoff wrote:
> Dear Helmut,
> On 2017-11-02 at 07:17, Helmut Kudrnovsky <hellik at web.de> wrote:
>> Ken Mankoff wrote
>>> Does GRASS (or GDAL?, proj4?) have a function (or addon) to provide the
>>> scale error for a given cell?
>> AFAIR there is now an area function in r.mapcalc in GRASS trunk to calculate
>> the pixel area.
> There is. I've just built GRASS 7.5. But the area() function just returns nsres*ewres for each cell, it does not consider projection errors.
You could run area() both in your projected location and in a lat-long
location (preferably using a similar datum), although you would have to
be careful in the definition of the resolution in each location.
Comparing the output should give you a notion of projection error.
For visualization you might want to try the Indicatrix mapper Plugin in
QGIS...
Moritz
