[GRASS-user] How to copy attributes from one layer to another?
Markus Metz
markus.metz.giswork at gmail.com
Wed Nov 22 23:34:58 PST 2017
On Thu, Nov 23, 2017 at 12:13 AM, Eric Patton <thepattonian at gmail.com>
wrote:
> Is there an easy way to copy all attributes from layer 2 of a vector
points map to layer one (which doesn't currently exist - is will need to be
created)?
> Alternatively, maybe all I really need is a way to rename layer 2 to
layer 1 while keeping all attributes intact.
You need to distinguish between category values of the vector points and
attribute tables linked to a particular layer.
You can change the layer number of category values from layer 2 to layer 1
with
v.category option=chlayer layer=2,1
Now you need to reconnect the attribute table from layer 2 to layer 1 with
v.db.connect
HTH,
Markus M
> Background: I need to move all the attributes to layer 1 in my point map
in order to patch vector maps together with v.patch.
> Thanks,
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171123/cb97156a/attachment-0001.html>
